1 - 4 of 4 Posts
I would like a picture of the 01 gt s premium stereo wire harness for the stereo . The one in the car from the factory .
Reason : The stereo in my car was stolen , wire harness too . That in-itself not a big deal. I've wired up a new stereo, no problem . Thing Is I would like to have the stereo lights dim when I turn on my driving lights . I have the harness diagram that displays, which each port is used for . However I don't have the color code for the wires in the ports . I just looking to narrow my search for the illumination wire . I will test the output voltage before connecting said wire to the stereo ,just to be safe ! Any input will be greatly appreciated .
^Green (pin #2 - I think) is OK for a +12V signal to dim.
Don't use the White w/Green stripe - it sinks to ground through the dimmer control.
Thank you !
I'll probably pull the stereo this weekend and check it out .
Pin #2 Light control switch Tail or Head (solid green )
I'll check with the fluke first, then I'll release the magic smoke from the stereo .
1 - 4 of 4 Posts
