#1. Why did toyota switch the knock sensor on the '02-up models? Is it better?
#2. Does a car have more knock at Idle then at 3k?
#3. Is there anything mechanicaly different about the '02 engine then the 00.
Reason I ask this is that my friend did the rev limiter conversion on his '02 GTS. Now it seems like the car is knocking when starting up. Sounds like a Diesel almost. BUt the sound goes away in higher RPM's.
Now I'm thinking it could also be Valve clearance or the Cam gear TSB. BUT it never hurts to look at all the angles.
Now if the 00 engine is a bit diff then the 02 engine. Would putting and 00 knock sensor and ECu on the 02 engine cause knock?
