1 - 12 of 12 Posts
Bring on the 12's...
Can these be 'cleaned' to improve their efficiency, like a maf? Probably not I'd have thought because they get all carbonned over anyway, but thought I'd ask...
Also, I have a spare sensor and the part number is 89465-20670. Does this go before the cat, or after the cat?
Nope. From what I understand, attempting to clean can actually cause more harm than good. The P/N you have is for a ZZT230 pre-cat sensor. I imagine you would want the Euro ZZT231 version - 89465-20690.
Ahhh...maaaaan...it wont work on my car then?! :bang:
Time to sell it on then, ahem...
This.
Yep, just buy a new one. Good to change these out probably every 60K or so anyway.
There's a difference betwen the US and Euro O2's? :confused:
Yeah I guess so...mieh, i'll just look at it as another mod that will help increase efficiency == power on my motor before doing a baseline pull.
I'll make a for sale thread and see if any of the gt guys want this sensor off me.
Yep. It would also be valid for a USDM GT.
? @ least different P/N's. The front USDM ones for a ZZT231 are: 89465-20700 for '00-'03, 04+ = 89465-20830. The Euro versions are: -20690 unless it is a NATO version... which uses the same as a USDM.
So, I would suspect Celicasaur's might be NATO. Maybe he can PM me a VIN to check. In either event, the sensor he has isn't correct for a ZZT231;)
NATO?
What kind of vin would you like? One from a 230 or a 231?
Yep, NATO, North American Treaty Organization country....
PM me your ZZT231 VIN
I'm not used to seeing a RHD result... lol. You have the Euro version. You want the 89465-20690.
Comes back to a ZZT231R-BLFVFW, made 1/2001, Color code 210, Trim Code LB23.
Discussion Starter · #11 ·
Euro? I thought mine was uk...but then they could just be the same thing in the grand scheme of things. Right, clearly I have the wrong 'spare' 02 sensor then and I need to make a for sale thread now :0:
Anything particularly interesting come up in the vin check? I've had it for over 4 years now, but whenever I look inside the rear hatch under the plastics I see a greeny colour...which is not colour code 210 as on the outside. Actually, no ignore me. It'll just take the thread O/T
Thanks for your help guys :)
Wasn't really a VIN check, per se. 210 is the original paint code. I'm not sure what the differences are between the Euro & the NATO versions. NATO versions may be what US soldiers can buy overseas and import w/o trouble? I don't know... all I know is that there are European versions and NATO versions. You have the European.
Yep, wrong spare sensor.
1 - 12 of 12 Posts
