1 - 10 of 10 Posts
Are the alternator, water pump, condensor, fuel pump(pressure the same?)the same on both the 1ZZ and the 2ZZ? Are they interchangable
Thanks
Discussion Starter · #2 ·
Up
Anyone know if the fuel pump for the 1ZZ has the same flow rate/pressure as the 2ZZ counterpart?
I have a 2ZZ-GE coming and would like to know what parts are interchangable before mounting it on the MR-S
Alternator is not the same, the 2zz has slightly higher output. The water pump is definitely not the same, and the 1zz water pump will not fit on the 2zz.
I don't know about the other items you mentionned, but check the repair and maintenance forum for some scans from the factory Celica service manual. When there's a difference between the GT-S and the GT, they mention it and usually show both parts.
Good luck with the swap!
Marc
Thanks. Good thing I got all the accessories. :)
What I really want to know is if the Fuel pump has the same specs.
The 1ZZ-FE pump should be enough though for the the stock power output :)
I'm not too sure about that. Under 6k maybe, but once you hit lift I think it's a different story. I am talking outta my ass but I something to consider.
I just checked on partznet.com, and they only list one fuel pump for all 00-03 Celicas, so unless there's a mistake with the listing, the GT and GTS use the same pump.
I also looked up the MRS, and even though Partznet does not show part #s, it looks like the same pump since they're exactly the same price, to the penny.
Marc
thanks a lot marcus.
Actually I thought so. Should have a constant pressure of 50psi IIRC. And even if they where not the same. The stock MRS pump does well at over 200hp on turbo cars :)
1 - 10 of 10 Posts
