yes you can put a 1ZZ crank in the 2ZZ motor, but you need custom rods and pistons. check out www.monkeywrenchracing.com and look for 2ZZ stroker. its not a drop in thing. you will need a new flywheel also (1ZZ type)
because, as already stated in this thread, it will raise the displacement from 1.8L to 2.0Lyoungxlos said:can someone please tell me how the 1zz is better than the 2zz crank??? i
yes, since the stroke of the piston is part of the equation for displacement. and sort of, I think its recomended that you lower the redline just a little..youngxlos said:i am confuse, so does that mean i don't have to bore out the block? and with this set up. could i do high compression pistons and rev high.
+1.Loser_guy said:yes, since the stroke of the piston is part of the equation for displacement. and sort of, I think its recomended that you lower the redline just a little..
thanks guys, I understand it better.Zer0 said:The crankshaft controls the stroke of the piston.
Displacement = pi x radius2 x height x # of cylinders x .000001 (for displacement in liters)
1zz-fe = 79 mm bore and 91.5 mm stroke [3.14 x (39.5 x 39.5) x 91.5 x 4 x .000001] = 1.79310171 liters
2zz-ge = 82 mm bore and 85 mm stoke [3.14 x (41 x 41) x 85 x 4 x .000001] = 1.7946356 liters
2zz-ge w/1zz crank = 82 mm bore x 91.5 mm stroke [3.14 x (41 x 41) x 91.5 x 4 x .000001] = 1.93187244 liters
I do not think so. MWR has some sick turbo setups. I do not think you could even reach 355whp on a N/A celica, from what I have read. Mabye 250 whp, max. MWR has a turbo GTS pushing 400 hp or something like that, on stock motor.krichards said:quick question? with all these modification options now available like cams, stroker kit, flywheel fuel management and all has anyone built a 12 second N/A celica as yet?
because those type R Integra fools been hyping about some 355whp N/A DC5 type R Integra that runs 12 seconds and I know we can beat that
That honda has a 2.4 or 2.5 liter engine - never gonna happen in a 1.8 liter Celi motor - 250 is probably the most you'll every hope to see to the tire on a full boogey high dollar race build.krichards said:quick question? with all these modification options now available like cams, stroker kit, flywheel fuel management and all has anyone built a 12 second N/A celica as yet?
