1 - 13 of 13 Posts
Wrecked Celica :D
found a celica gt in junkyard with a decent CAI for $30, i didnt no at the time the 2zz has a bigger throttle body so, might as well make use of it,
so cant i just weld it a bit to make it fit? or its just plain retarded and cheap of me?
Not really Gino - the 1ZZ has a resin (plastic) manifold and you can't weld on a new TB flange
You mean the throttle body? Call maxbore.
no, the IM, u said i needed to port the IM if i was to bore the TB.... or at least thats what i thought you said, unless u meant it the other way around like if im going to port the IM i need to bore the TB
Adding a bigger TB might gain you high end hp, but only at the sacrifice of low end torque..If running your car s/s not worth it imo..I ran a 90mm TB on a 2zz and it was weak sauce until about 4k then hold on! Being in the upper R's all the time was fun, but short lived, starved the motor of oil wiped all the bearings only after a month of it...
1 - 13 of 13 Posts
