I have a 2002 Celica GT and the cooling loop on the power steering that runs out in front of the radiator (or AC condensor) is cracked and leaking. I need to replace it, has anyone done this before?
I have a few questions:
- Where to get a replacement, likely Toyota?
- Find out how much work it is to replace myself?
- Does the system auto bleed any air or will I have to bleed it?
Thanks
You can just us an off the shelf transmission fluid cooler with some rubber tube as fittings. Won't be as pretty but will work just as well and cost much much less.
^Just make sure to check the hangers/clamps from time to time though, they are known to fail. Also watch for corrosion between them and the aluminum condenser unit if any metal is exposed during installation.
