If you drive the stick properly, you will get better MPG easily.Originally posted by Yossarian
i have an auto and I like it. It actuallygets better gas mileage than the stick, but its seriously underpowered (torque converter powerloss) and has bad gearing.
If you want to modify it then probably a stick is better unless you intend to go turbo then an auto isnt that bad.
I Know. But if you drive stick properly it will get better mileage.Originally posted by Yossarian
Well, according to Toyota the auto gets better mileage.
:werd:Originally posted by NoRulzAt140 Mph
It also helps to put it into neutral when you don't need to accelerate like down a hill or approaching a stop light with no cars behind you.Blue Bomber said::werd:
Nothing like shifting at 2000 RPM. :chuckles:
Now that is PERFORMANCE!Originally posted by KSilver2000
It also helps to put it into neutral when you don't need to accelerate like down a hill or approaching a stop light with no cars behind you.![]()
I am a rebel. I take Risks. Dare I say I shift at 2500.Originally posted by Blue Bomber
:werd:
thats 4500 rpms closer to redline calm the hell downOriginally posted by NoRulzAt140 Mph
before my swap, i got about 320-340 per tank (hitting lift on average once a day). after my swap, i got 340-360 per tank when i drive hard (a lot harder than i drove my automatic) and 360-430 when i drive sanely or mainly freeway miles.NoRulzAt140 Mph said:If you drive the stick properly, you will get better MPG easily.
I have a lead foot. Sorry.Originally posted by CeliKill180
But as said. Generally, AUTO get sbetter.Originally posted by modenaplz
so what i'm trying to say is that i don't have to shift at 2.5k RPM just to save MPG over the automatic celi.
You own a GT-S so I am not for sure if it gets better gas mileage than the auto GT. If it was so easy to get better gas mileage with a stick why would Toyota advertise the auto as having better mileage? When you drive the car in high gears at low speeds you end up having to give more gas to get moving so I do not buy the argument that you can get better gas mileage with a stick. The gearing and computer in the GT combine for the more precise, and efficient, consumption of fuel.modenaplz said:before my swap, i got about 320-340 per tank (hitting lift on average once a day). after my swap, i got 340-360 per tank when i drive hard (a lot harder than i drove my automatic) and 360-430 when i drive sanely or mainly freeway miles.
Your in denial.Originally posted by Yossarian
You need to substantiate that claim and bring it up to Toyota then.NoRulzAt140 Mph said:Your in denial.
I get 37-40 MPG in my 5 SPEED easy. Driving hard I get 30-35.
