41 - 60 of 91 Posts
Super Moderator
Discussion Starter · #45 ·
Update!
Novitec Rosso Race 848
Underneath the striking aluminum skin that sports the unusual color combination of matte white and grey beats an extremely powerful heart: The Novitec Rosso Race 848 twelve-cylinder twin compressor engine produces 848 hp / 624 kW of power and has a peak torque of 842 Nm. Powered by this engine the car sprints from rest to 100 km/h in less than 3.4 seconds, to 300 km/h in just 23.7 seconds, and reaches a top speed in excess of 345 km/h. This exclusive special model also features an aerodynamic-enhancement kit developed in the wind tunnel, three-piece 21-inch wheels with matching sports suspension, a high-performance brake system and exclusive interior options.
The Novitec Rosso Race 848 is powered by an evolutionary stage of the tried and proven twin-compressor engine conversion for the six-liter V12 four-valve engine of the F599. For an additional power increase of 40 hp / 29.4 kW both mechanical chargers were fitted with modified turbine blades, several details of the engine peripherals were modified and the engine electronics were reprogrammed.
It's a bloody masterpiece.
Boobze
On that show Ultimate Factories they had one of the episodes on the Ferrari factory that built this.... highly recommend checking it out.
Super Moderator
Discussion Starter · #49 ·
Yup, seen that, the ZO6, Camaro, Veyron and a Rolls-Royce (forget which one). All of them were great episodes.
Update!
Ferrari 599 Hybrid Concept: First Photos Leak
Photos aside, we asked around and our sources gave us some inside information on the hybrid system featured on the 'green' 599 concept.
The system comprises of an electric motor producing around 100 horsepower and 110 lb-ft of torque that is attached on the back of the rear-mounted transmission, and a battery pack located under the floor.
The extra power is said to compensate for the added weight which is said to be close to 100 kilos or about 220 pounds, making the 599 Hybrid faster than the stock model.
:drool:
Super Moderator
Discussion Starter · #50 ·
Update!
PRESS RELEASE
FERRARI DEBUTS AT GENEVA WITH THE HY-KERS, A 'VETTURA LABORATORIO'
The HY-KERS displayed at the Geneva Motor Show is an example of how Ferrari is studying the application of hybrid technology to high-performance sports cars. Central to Ferrari's objectives is maintaining the balance, handling and performance characteristics typical of its cars despite the inevitable disadvantages in terms of weight represented by applying hybrid solutions to existing models.
To this end Ferrari has employed its racing experience to adapt a lightweight hybrid drivetrain to the 599 GTB Fiorano with the aim of ensuring that vehicle dynamics are unaffected. This was achieved by the careful integration of all system components, positioning them below the centre of gravity and ensuring that interior and luggage space are entirely unaffected. Similarly the flat lithium-ion batteries are positioned below the floorpan of the car inside the aerodynamic underbody. The result is a centre of gravity that is even lower than in the standard car. In addition, a part of the weight gained by fitting the electric motor, generator and the batteries is offset by being able to do away with the traditional starter motor and battery.
Ferrari has also applied its F1 technology to the design, engineering and construction of a new kind of electric motor which also helps optimise the longitudinal and lateral dynamics of the car, enhancing traction and brake balance. The motor cuts in during acceleration, providing instantaneous torque when moving away from a standstill and during overtaking manoeuvres, with torque control a function of grip, gear and accelerator pedal angle. Depending on vehicle speed and engine load – for example in town driving – the hybrid system can also function as a full-electric drivetrain. The result is a direct reduction in consumption and emissions. The motor also features a unique cooling and lubrication system for maximum efficiency under all operating temperatures and loads. The castings of the motor are made in the Ferrari foundry, complete with Prancing Horse motif.
Weighing about 40 kg, the compact, tri-phase, high-voltage electric motor of the HY-KERS is coupled to the rear of the dual-clutch 7-speed F1 transmission. It operates through one of the transmission's two clutches and engages one of the two gearbox primary shafts. Thus power is coupled seamlessly and instantaneously between the electric motor and the V12. The electric motor produces more than 100 hp as Ferrari's goal was to offset every kilogram increase in weight by a gain of at least one hp.
Under braking the electric drive unit acts as a generator, using the kinetic energy from the negative torque generated to recharge the batteries. This phase is controlled by a dedicated electronics module which was developed applying experience gained in F1 and, as well as managing the power supply and recharging the batteries, the module also powers the engine's ancillaries (power steering, power-assisted brakes, air conditioning, on-board systems) via a generator mounted on the V12 engine when running 100 per cent under electric drive. It also incorporates the hybrid system's cooling pump.
In keeping with Ferrari's 360-degree approach to efficiency and its commitment to environmental sustainability, new technologies for its road cars are matched by the considerable investments already made to reduce the environmental impact of the company's production activities in Maranello.
After the inauguration of the photovoltaic installation on the roof of the Mechanical Machining facility in January 2009, which reduced the factory's power requirements by over 210,000 kWh annually, 2009 also saw the opening of the trigeneration plant (the simultaneous production of power, heat and cooling from a single source) – the first of its kind to be implemented by a sports car manufacturer. This enabled Ferrari to reduce CO2 emissions by 15 per cent, with the goal of reaching a reduction of over 40 per cent by the end of 2010. Thanks to these ecological solutions, Ferrari is completely autonomous for its energy requirements.
Love that display. You can see all of its hybrid guts in the reflection.
Super Moderator
Discussion Starter · #51 · (Edited)
Update!
Ferrari 599 GTO
Standing for Gran Turismo Omologato, the 599-spec GTO will produce some 700bhp from the regular car’s Enzo-derived 6.0-litre V12. Although none of the spec is confirmed yet, early brochures have spilled some of the technical detail and we understand that the GTO will rev to a neck-tingling 9000rpm.
The regular 599 develops 611bhp and 448lb ft, and the GTO version is tipped to top 500lb ft of twist. Make no mistake, this 599 will be as fast and furious as the Scuderia spec 430.
Ferrari’s new GTO: a lightweight diet
The GTO will pack a load of carbonfibre – the roof on this scarlet test car even appears to be fashioned from the black stuff – to bring the weight of the 599 below 1690kg.
Stickier tyres and a faster map for the F1 sequential gearbox should bring the 0-62mph time down to some 3.5sec.
Expect the 599 GTO to receive styling tweaks over the regular model, including aero tweaks and cooling vents.
Super Moderator
Discussion Starter · #53 ·
Update!
Ferrari 599 HY-KERS Hybrid System Explained in 3D Animation
Hybrid technology is one of the solutions examined by Ferrari in its on-going research and development into making its production cars ever more efficient. Experimenting with alternative technologies represents the company's long-term strategy after the announcement in 2007 of a five-year plan to reduce fuel consumption and emissions across the range. With the launch of the Ferrari California (2008) and the 458 Italia (2009), in fact, Ferrari's average fuel consumption and CO2 emissions figures have already been reduced by around 30 per cent compared to 2007.
Ferrari has also applied its F1 technology to the design, engineering and construction of a new kind of electric motor which also helps optimise the longitudinal and lateral dynamics of the car, enhancing traction and brake balance. The motor cuts in during acceleration, providing instantaneous torque when moving away from a standstill and during overtaking manoeuvres, with torque control a function of grip, gear and accelerator pedal angle. Depending on vehicle speed and engine load - for example in town driving - the hybrid system can also function as a full-electric drivetrain. The result is a direct reduction in consumption and emissions. The motor also features a unique cooling and lubrication system for maximum efficiency under all operating temperatures and loads. The castings of the motor are made in the Ferrari foundry, complete with Prancing Horse motif.
After the inauguration of the photovoltaic installation on the roof of the Mechanical Machining facility in January 2009, which reduced the factory's power requirements by over 210,000 kWh annually, 2009 also saw the opening of the trigeneration plant (the simultaneous production of power, heat and cooling from a single source) - the first of its kind to be implemented by a sports car manufacturer. This enabled Ferrari to reduce CO2 emissions by 15 per cent, with the goal of reaching a reduction of over 40 per cent by the end of 2010. Thanks to these ecological solutions, Ferrari is completely autonomous for its energy requirements.
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/AnJunE0QMjg&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/AnJunE0QMjg&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Super Moderator
Discussion Starter · #54 · (Edited)
Update!
Ferrari 599 GTO Photos Leaked
As the world gets closer to the official reveal of Ferrari's 599 GTO, and just a short while after the price list was leaked, the internet has spewed out what appear to be pics of an official GTO show car.
Obviously, no details at this time.
Super Moderator
Discussion Starter · #55 ·
Update!
Revealed on www.ferrari.com: the new 599 GTO - The fastest ever road-going Ferrari
Now available on www.ferrari.com are the first photos and information on the new 599 GTO, an extreme V12 berlinetta developed to a specific performance-oriented brief. The 599 GTO is, in fact, the company's fastest ever road car. It is an exclusive limited edition special which, in true Ferrari tradition, is a completely new concept, albeit inspired by a production car. In fact the 599 GTO is based on the 599XX, the advanced experimental track car, and can be considered almost a road-going version.
The 599 GTO is reserved for just 599 clients who seek the maximum expression of high-performance driving. The 599 GTO benefits directly from the technological transfer from racing and set a record lap time at Fiorano in 1'24".
The Fiorano lap time provides just one indication of the potential of this car. Just as significant are the technical specifications – 670 hp in a 1495kg car represents a weight-to-power ratio of just 2.23 kg/hp, and ensures a 0-100 km/h acceleration time of just 3.35" as well as a top speed of over 335 km/h.
Fundamental to the GTO's performance is the innovative approach to chassis development which, for the first time on a production car, saw the integration between a handling set-up tuned for a level of responsiveness that is close to the limit and highly sophisticated electronic controls. The result is the almost complete absence of understeer and a truly communicative chassis.
As is Ferrari's policy, every new Ferrari features new solutions for a road car. Thus the 599 GTO is equipped with the latest, second-generation carbon-ceramic brakes which are lighter and offer better performance, new aerodynamic innovations, such as the wheel doughnuts which increase aerodynamic efficiency as well as improve brake cooling, and the Supersport tyres developed by Michelin include a wider front tyre for greater roadholding. The driver-car interface is also new with the adoption of the Virtual Race Engineer (VRE) which provides the driver with instantaneous information on performance.
The 599 GTO's more aggressive character is also apparent in a number of styling elements that recall the 599XX and from the powerful sound of the V12.
The GTO (Gran Turismo Omologata) moniker instantly calls to mind two Ferraris that have entered the collective imagination as symbols of performance. After the 1962 250 GTO, which swept the boards in GT racing categories in the 1960s and is now a highly prized collector's car, came the iconic 1984 GTO, which basically invented the entire modern supercar genre.
The web special includes photos, videos and interviews on the new car, while an exclusive preview for a small number of Ferrari clients will be held on April 14th at the Military Academy in Modena. The public debut of the 599 GTO will instead be at the Beijing International Motor Show at the end of April.
It's OFFICIAL!
Fvck.
My.
Life.
Super Moderator
Discussion Starter · #59 ·
Update!
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/T1YmudW177o&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/T1YmudW177o&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Super Moderator
Discussion Starter · #60 ·
Update!
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/cV-O4RWcSHM&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cV-O4RWcSHM&hl=en_US&fs=1&color1=0x5d1719&color2=0xcd311b" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
41 - 60 of 91 Posts
