1 - 20 of 51 Posts
Super Moderator
2011 Rolls-Royce Ghost
Back in January, spy photographers spotted the first prototypes of the "baby" Rolls-Royce at BMW's test center in the Arctic Circle. The car has now been photographed on a busy street and in detail by our spy photographers.
As previously reported, the new Roller is expected to share a platform with the next-generation 7-Series. Rolls-Royce will utilize the Bimmer platform to build a less expensive luxury car. Of course, "less expensive" in this case means the $150,000 to $200,000 range.
Despite the baby Rolls' close connection with the 7-Series, the two car's won't share any visible interior designs or parts. The new Rolls-Royce model will also have a unique wheelbase, as well as a unique roof and hood hight and track.
The new model will also use a unique range of engines, though they will likely be based on BMW engines — such as the twin-turbo V8 slated for duty in the X6. Sources also say that Rolls-Royce is considering offering the new car with a diesel option.
Look for the Baby Rolls to hit dealer showrooms in late 2009.
Of course in Rolls Royce terms it means this "baby" is probably bigger than 7-series itself. Reuze baby (that's Dutch)
It is known.
neological said:
I could not possibly bring myself to care about this car.
Me either.
00 MRS - 2ZZ NA
How big is the engine? And I want to see those doors open up!!!
Super Moderator
Discussion Starter #13 (Edited)
Update!
ROLLS-ROYCE GHOST
"The balance of refinement and dynamic ability is astonishing."
Helmut Riedl, Engineering Director
When considering a Rolls-Royce car it is usual to think of wood, leather and chrome, but the company has its roots in engineering. The refinement of its end product stems from its engineers' desire to get the smallest details correct. Long before the interior items are prepared, experts are working to ensure that the chassis components, power trains and bodywork are operating in fluid harmony. This is a world where welds are an art form and craftsmanship exists at a nano level.
Ghost is built around a steel monocoque body, which means there is no separation of chassis and body. The advantage of this construction is a reduction in exterior dimensions while preserving interior space. Consequently while Ghost is over 400mm shorter overall than the Phantom saloon its interior space is comparable.
The body has been engineered with a double front bulkhead to help insulate the interior from engine noise. It is constructed from steel sections and then wrapped in steel panels, which are brazed by hand. This allows a near-seamless join, which is then sanded by hand until it is perfect. In total, Ghost's frame contains 4.9m of seam weld and braze and 6,988 spot-welds. The bonnet and windscreen surround are then honed from aluminium.
"A Rolls-Royce should be graceful in every way: the way it handles, feels and brakes."
Ghost rides on a bed of air. Double-wishbone front suspension and multi-link rear suspension work with an intelligent, four-cornered, air-suspension system and electronic variable damping to deliver the refinement that has been associated with Rolls-Royce for more than 100 years.
The new air suspension system in Ghost is so sensitive that it can detect even the smallest of changes. For example, it will sense the movement of a single rear passenger from one side of the seat to the other and compensate accordingly. A complex computer system reads multiple inputs from sensors around the car; the dampers alone make individual load calculations every 2.5 milliseconds. This ensures not only perfect comfort but also precise steering and dynamics for the driver. The air suspension system also incorporates a lift and kneel function, raising or lowering Ghost by 25mm.
Ghost also has a series of complex electronic aids to keep it composed on virtually any surface. These include Anti-Roll Stabilisation, Dynamic Brake Control and Dynamic Stability Control, including Dynamic Traction Control and Cornering Brake Control. These individual technologies work together under dual Integrated Chassis Management systems, meaning that even when subjected to a vigorous test Ghost remains perfectly poised. Its handling and safety systems operate as one, imperceptibly to the driver and passengers, to maintain optimum contact with the road in any condition.
"Our challenge," says Engineering Director Helmut Riedl, "has been to preserve the prerequisite levels of comfort while delivering the most modern, dynamically interesting drive ever in a Rolls-Royce."
Ghost is powered by a brand new, 6.6 litre twin-turbo V12 engine, unique to the model. Featuring direct injection, it produces 563bhp – enough to propel Ghost from 0-60 mph in just 4.7 seconds* and on to an electronically governed top speed of 155mph. With 780 Nm of torque available at just 1,500rpm, delivery of power is immediate and extremely smooth.
Power is transmitted through an eight-speed, shift-by-wire, automatic ZF gearbox. What this achieves is a feeling of endless, surging power, which is illustrated by the power reserve gauge on the fascia, replacing the more common rev counter. The new powertrain delivers this performance while emitting just 317g/km of CO2.Fuel consumption is 20.8 mpg / 13.6 l/100km.*
Safety remains paramount and the very latest technologies are used in Ghost. Side-impact beams in the front and rear doors combine with progressive rear crumple zones to absorb impacts. The Advanced Crash and Safety Management (ACSM) system takes measurements 2,000 times per second from sensors located around the vehicle. The ACSM uses this information – in conjunction with the engine and chassis management systems – to judge which safety features to deploy in which areas in the event of an accident. If necessary, ACSM will activate – among other things – seatbelt pre-tensioners and all encompassing airbags surrounding the cabin, creating a safe zone for all occupants.
that's a shame someone puked all over the dashboard, it went everywhere
Never seen real birds eye maple have you?
1 - 20 of 51 Posts
