1 - 4 of 4 Posts
Super Moderator
2012 Hyundai Accent Previewed
Unveiled at the Guangzhou auto show in China, the Accent will be sold as the Verna overseas.
In China two engines will be offered including a 1.4-liter 4-cylinder with 105-hp and 100 ft-lbs of torque, as well as a 1.6-liter 4-cylinder with 121-hp and 114 ft-lbs of torque. The latter engine is expected to be offered in the North American Accent and achieve over 40-mpg highway.
The official reveal for the next Accent is pegged to take place at the New York Auto Show in April.
A shrunken Elantra.
It does indeed. I'm a bit disappointed. Not that I care that much, a lot of the Hyundai/Kia cars have taken cues from other cars the past few years.
Super Moderator
Discussion Starter #4
Update!
2012 Hyundai Accent Gets Most Power, Fuel Economy in its Class
Keeping the same styling seen on the Sonata and the new Elantra, the 2012 Accent is powered by a direct-injection 138-hp 1.6-liter 4-cylinder that makes 123 ft-lbs of torque and according to the Canadian press release gets 4.7 L/100 km highway and 6.4 L/100 km regardless of whether you choose the 6-speed automatic or manual. That works out to an incredible 50-mpg highway and 37-mpg city. (Those numbers are, however, imperial and in the U.S. you’re looking at closer to 41-mpg and 30.5 mpg).
Having grown in size, the new Accent is now 70mm (2.7-inches) longer between the wheels and 5mm wider. This not only makes for added interior space, but the Accent also delivers a sizable amount of cargo volume with 14 cu-ft of trunk space with the sedan and 17.2 cu-ft with the hatch. Despite all this, weight was kept to a minimum, with the new Accent sedan weighing just 2,392 lbs, while the hatchback model is slightly heavier at 2,429 lbs.
1 - 4 of 4 Posts
