41 - 60 of 360 Posts
· Administrator
Discussion Starter · #43 ·
· Administrator
Discussion Starter · #45 ·
<iframe width="640" height="360" src="https://www.youtube.com/embed/3ImGRhxTGzQ?rel=0" frameborder="0" allowfullscreen></iframe>
In early March 2015, there has come: At the Geneva Motor Show to present the four rings, the second generation of the Audi R8. First, we show you the first pictures of the super sports car on the race track in southern Spain Ascari. At the wheel racer Frank Stippler. The sound of the new Audi R8 V10 is distinctive due to its naturally aspirated engine.
<iframe width="640" height="360" src="https://www.youtube.com/embed/oyQ-lglmBbM?rel=0" frameborder="0" allowfullscreen></iframe>
· Administrator
Discussion Starter · #47 ·
First Official Photo Of 2016 Audi R8
http://www.carscoops.com/2015/02/fi...itter&utm_campaign=Feed:+Carscoop+(CARSCOOPS)
Based on the same platform as the Lamborghini Huracan, the new Audi R8 will launch in two versions, with a 540hp V10 and a top-of-the-line 610hp V10 Plus.
The latter has a heavily reworked 5.2-litre unit which allows the V10 Plus to sprint from 0 to 100 km/h (62 mph) in 3.2 seconds, an improvement of 0.3 seconds compared to its predecessor. Top speed is 330 km/h (205 mph).
Unfortunately for purists, there’s no manual transmission option, with the sole transmission offered being the 7-speed S-Tronic double-clutch gearbox.
Later on, the R8 may also get a smaller V8 engine, possibly the biturbo 4.0-liter used by other models of the VW Group. However, there’s nothing official about a V8 yet.
· Administrator
Discussion Starter · #48 ·
New Audi R8 Officially Revealed
http://www.carscoops.com/2015/02/all-new-audi-r8-officially-revealed.html
The V10 mid-engine supercar is up to 50kg lighter than its predecessor, with the top-of-the-range V10 Plus scoring 1454kg, thanks to the new Audi Space Frame chassis which combines aluminium and carbon fibre reinforced plastics in its construction, something we’ve seen already in its Italian cousin.
An updated 5.2-litre V10 engine, available with two outputs, will be the only choice during the launch. The first version makes 540hp and 540 Nm (398.3 lb-ft) of torque while the V10 Plus scores a very healthy 610hp and 560 Nm (413.0 lb-ft) of torque, allowing it to accelerate from zero to 62mph (0-100km/h) in 3.2 seconds, 0-124mph (0-200km/h) in 9.9 seconds and it will keep going until it reaches 205mph-330km/h. The 540hp version sprints to 62mph from standstill in 3.5 seconds and it can reach a top speed of 201mph (323km/h).
According to Audi the updated V10 now features an additional indirect injection to compliment the direct injection, making the engine to use less fuel and produce more power. A Cylinder-On-Demand system is also present, shutting one of the two cylinder banks in light throttle loads, further improving the fuel efficiency. The R8 V10 averages 11.8 lt/100km (19.9 US mpg) with CO2 emissions of 275 gr/km. For the R8 V10 plus those values are 12.4 lt/100km (19.0 US mpg) and 289 gr/km. Compared to the previous model, the new R8 is using less fuel up to 10 percent, also due to the new start-stop system.
Gone is the option of the manual gearbox with the 7-speed S-Tronic transmission to be the only one to choose from. This is combined with a newly developed Quattro system which can distribute the torque according to the respective driving conditions, sending up to 100% of the torque in a single axle in some extreme cases.
The driver has now the choice of four driving modes (comfort, auto, dynamic and individual) through Audi’s drive select dynamic handling system. The standard system takes into account the engine characteristics, steering, S tronic transmission and quattro drive system as well as optional extras such as Audi magnetic ride, the exhaust flaps and dynamic steering.
Audi’s virtual cockpit, first seen on the new TT is here, allowed the designers to create a more minimalistic interior, with all the information needed in front of the driver. Details like the three-dimensional designed air vents are set to remind “the air inlets of a race car”.
The all-electric brother
Audi will also reveal next to the gasoline R8s an all-electric version of its supercar, the R8 e-tron. Equipped with a large T-shaped 92 kWh battery, structurally integrated into the center tunnel and behind the occupant cell, the electric R8 achieves a range of 450km (280 miles). The R8 e-tron is equipped with a Combined Charging System (CCS), which allows charging with direct and alternating current and according to the Germans, the time for the battery to be fully charged is less than two hours.
According to the press release,"the power is now twice 170 kW and the maximum torque twice 460 Nm (339.3 lb-ft)" which means that the R8 e-tron has either two electric motors with 230hp and 460 Nm (339.3 lb-ft) of torque each, or one (?) making it capable for a 0-62mph in 3.9sec and a restricted top speed of -and we quote here- 210 km/h (130.5 mph) or 250 km/h (155.3 mph). With targeted modifications to the outer shell and on the wheels, the Audi R8 e‑tron achieves an aerodynamic drag coefficient (cd) value of 0.28.
<iframe width="640" height="360" src="https://www.youtube.com/embed/ztkrZQMes90?rel=0" frameborder="0" allowfullscreen></iframe>
Audi presented at the Geneva Motor Show, the new Audi R8: No model with the four rings is closer to Motorsport, none is sharper and more dynamic. Before its premiere, we show you the first motion pictures of the high-performance sports car.
· Administrator
Discussion Starter · #49 ·
<iframe width="640" height="360" src="https://www.youtube.com/embed/sQmA-7bDYxc?rel=0" frameborder="0" allowfullscreen></iframe>
A mid-engined sports car with impressive performance figures – and looks to match: muscular, poised and expressive. The R8 confidently displays its engine beneath the glass of the rear window, aspirated by characteristic sideblades. A vehicle so close to the world of racing that it is a highlight in everyday life.
· Administrator
Discussion Starter · #60 ·
<iframe width="640" height="360" src="https://www.youtube.com/embed/A2W8MWLw8mI?rel=0" frameborder="0" allowfullscreen></iframe>
<iframe width="640" height="360" src="https://www.youtube.com/embed/1uCzQCdCC1U?rel=0" frameborder="0" allowfullscreen></iframe>
