1 - 9 of 9 Posts
215-40's diameter is a bit smaller than stock 205-50/16 and 225-45/17 is a bit bigger. Which one I should go with?
Thanks for your advices...
Erik
2000 Sportshift Silver GT-S
Tein suspension kit
Enkei Racing RSF-2/17 inches Mags
Marangoni 215/40-17 High Performance Tires
I didn't think about recalibrating my speedometer when I bought rims. I have 18" rims w/, I think, 255/40's. How would the larger rim and tire effect my speedometer. Will I be going slower than I think???
tearemup: No you would be actually going faster than you think you are. The overall diameter of 225/40 on 18's is larger than our stock by about 1 inch.. Do some math and figure out the circumference difference. Its about 5%.. So if your speedometer says 65, then just add 5% to that, and thats your real speed..
My math might be wrong.. just assume u should add about 5-7mph.
Just use command sense..
The 215 or 225 are for width of the tire... which make the traction difference... speed doesn't make any different....
But when it comes to 40,45 and with that the rim size.. 16, 18 etc.... that makes the difference in speed....
When those gets bigger.... your actual tracel speed increase.. compare to your actual speedometer...
Cause of the circomflence... dang can't speel....
OK.. too much math.. headache..... later
If you log on to tirerack.com, you can bring up tire specs for any tire they carry, and they list overall diameter. Compare it to stock and check how close it is.
I reccommend 215/45/17 works for me...
<IMG SRC="http://forums.off-topic.net/images/smilies/boink.gif" border=0><IMG SRC="http://www.imagestation.com/picture/sraid26/pb6c7ba6c9e9e9201d40eb9340f796618/fe37e4da.jpg.orig.jpg" border=0>
1 - 9 of 9 Posts
