1 - 8 of 8 Posts
I'm buying new tires and I'm keeping the stock rims.... I'm gettin yokahoma ES100's.... It has them on there now.... I'm just buying 2 of them since the rest are ok.... right now it has 205/50/16zr on them... I wanna go a lil wider to like 215... the problem is they don't make 215/50/16ZR so should I try and go to a 215/45 or 215/55?? I do a lot of aggressive driving, straight line and hit up the back roads frequently.... I like the tires they seem pretty good.... so what do you all think??
discount tire says it's ok!
Plus Zero
185/65-15
Plus One
205/50-16
215/45-16
225/45-16
the front will have the 215/45/16's and the rear is gonna have the 205/50/16's will this be a problem at all??
doesn't matter cuz they don't make the yoka ES100 in a 215....
45 can and most likely damage your rims if you go over potholes and bad roads. its has a great grip on the road but risky.
So you are going to stick with the 205s?
AVSES100 Size Chart
They do have a 225-50-16 with an approved rim width of 6 to 8 inches. 6.5 should be ok. Their 225-45-16 minimum width is 7 inches though.
dB
I saw 225s on a car and they bulged a lot on the stock tire.... it was kinda ugly....
1 - 8 of 8 Posts
