The engine looks largely untouched, which means it's around 320hp at the crank which would be around 260whp.
Specifically, this appears to be a post-85 245 with a 2JZ-GTE inline-six likely borrowed from an MK4 Supra. If it's untouched, it should put out the then-maximum Japanese 280 HP.
A bit higher than that.The engine looks largely untouched, which means it's around 320hp at the crank which would be around 260whp.
I was basing myself on the engine being a JDM 2JZ. The location is unlikely to be the US, based on the plates.A bit higher than that.
Usually I've seen JDM 2JZs dyno at 260whp, but USDM 2JZs are tipping close to 300whp.
Look at the sign behind the car... I doubt that is a USDM 2JZA bit higher than that.
I'd say Hongkong, since it's RHD.Look at the sign behind the car... I doubt that is a USDM 2JZ
whyd you ask that?are these bimmers from New Jersey?
no kidding. thats awesome.Looks right at home.
