Hello guys.
Here's my situation.
I got 2ZZ-GE 2001 Japanese Toyota Corolla Fielder with 6sp C64 transmisson. Im gonna swap engine and transmission it in my car mr-s.And reverse 1zz engine and 5sp C56 transmission in toyota corolla.
So my question is:
can I use 2zz harness on 1zz-fe engine after swap? I mean can I start an engine with such modification? I know that it may be a different pinouts, but what if I install the wire pins from the scratch?
Thanks in advance
since this is overseas stuff i cant say for sure, however USDM you can run a 1ZZ on 2ZZ with no problem. all you have to do is change the pins in the TPS plug.
So guys, I received this 2zz JDM corolla fielder wagon. I made a swap from that car to toyota mr-s engine + transmission.
And I put 1zz + 5sp transmission in fielder with 2zz engine harness + 2zz fielder ecu.
Engine starts but without MAF, rpm wont go over 3000. I think it's in safe mode. If I insert maf, engine wont start.
So whats the solution? what do you think guys?
