61 - 67 of 67 Posts
I have a question I have been reading thru many post. Can not seem to find this question and answer.
I have an 01 gt. Motor is blown. I have an 03 vibe gt complete car. What all do I need from the vibe to do the swap? Also in process of removing the motors from their respective homes, I have noticed several differences like the engine harness to ecu and also at the fuse boxes... do I need to do some repinning here
Super Moderator
Discussion Starter #62
use only the engine from the vibe. manifolds, sensors, wiring, etc. all from the celica. you might also have to drill and tap the axle carrier bracket holes.
So should I use the transmission from celica and swap the flywheel from the vibe over? Using the engine and ecu from vibe and all else from celica I would then need pin the lift to the ecu correct?
Super Moderator
Discussion Starter #65
use whatever clutch and flywheel you want, just keep them the same combo.
you can open the Vibe harness and de-pin the LIFT wires and then add that to the GT harness
Ok awesome. Thanks so much for the input. I will keep you posted on the progress over the next while as I progress... I am sure I will have a few more questions..
61 - 67 of 67 Posts
