does any one know if there is anyway i could get a 2zz swaped gt to pass inspection ny or am i gonna have to stay with my 1zz? any info's appreiciated.
Its easy - just get a midpipe with cat as well as the engine assembly and a stock GTS ECU. And make sure that the engine you get is one year newer than your car in case they notice.
they don't do a visual inspection in NY I'm pretty sure... at least on my inspection thing all they did was check tires brakes and do an OBD-II check I'm pretty sure so as long as you have the GTS ECU so it won't set off any emissions warnings you should be fine.
thanks for all the input
