So, I've been reading up on what it would take to swap a 2ZZ into a GT, and at this point I'm wondering if it's even worth the power difference. I have a 6 speed tranny from the GT-S swapped in, so that shouldn't be an issue, But I'd like a bit more info on what else I'd need, (Wiring harness, cluster, motor mounts, etc). I looked into a K20 swap also, but ultimately decided it wouldn't be worth all the fabrication and money.
Any info helps, thank you.
Theres a buncha threads on this already and there are a few stickys that tell u EVERY thing u need
2000 GTS Turbo
2000 CELICA GTS
If you can find a wrecked donor car, all the part you would need will be on the donor. I've done a couple, I've also swapped out the automatic transmission for the manual, and anyone that says it's easy is full of crap. Good luck
Uh
Help I've swapped my ones easy for the two ZZ and I can't get any power came with the six-speed and I don't have any power what's wrong
