1 - 20 of 20 Posts
holy crap, thats my old car!
there is GTS rear disk conversion, Bilstein coilover kit, and the front lower control arms have ES bushings in them. if you can access there is also front lower tie bar on it.
Definitely my old car. :(
200 for the tails? even I didn't pay that much for them.
Also get the 03 rear trunk handle, it has the fancy brushed aluminum accent. It also has TRD air filter, Stoptech front pads and SS braided lines in all four corners. and hotchkis front sway bar.
#GetTheCoolShoeshine
it wasnt him, he sold it not that long ago :sadpace:, i saw it in person it was really clean, kim took good care of her for over 10yrs, sucks new owner couldnt enjoy it more thn 2months
Ask them how much for the torsion bar and leaf spring!
engine, trans, suspension, electrical, lights, strut, spindle, lower control arm, cross member, rack & pinion, door, bumper, injector, head, cam shaft, pulley, shifter, pedal, wheel, hub, door handle, air flow meter, control module, ignition switch, window switch, window motor, regulator, actuator, solenoid, latch, hinge, trim panels, molding, glass, abs pump, hubcap, reinforcement, climate control, ash tray, lighter, seat, headrest, armrest, radio, cd player, alternator, starter, power steering pump, tension pulley, tail lamp, wire, mirror, computer, air bag, headlamp, radiator, ac condenser, fan, blower motor, dash, glove box, radio face plate, combo switch, lock cylinder, fender, hood, bracket, grille, center console, torque convertor, bell housing, oil pan, timing cover, valve cover, sunroof, sun visor, headliner, belt molding, speedometer, wiper, throttle body, intake manifold, exhaust manifold, muffler, tag axle, I beam, axle shaft, tension rod, core support, inner fender, fender liner, master cylinder, brake booster, clutch, flywheel, idle control, ignition coil, crank angle sensor, cam sensor, speaker, sub woofer, trunk lid, spoiler, rocker molding, center post, cab corner, drive shaft, transfer case, leaf spring, torsion bar, spare carrier, idler, fender flare.
fools runnin a Honda 2000
kim's old car? I want roll cage!
no roll cage in there, sold it a while back.
I do have a front pair of TVS Hotchkis coilovers for sale though, I forgot about these.
$150 (in need of rebuild)
i'm pretty firm at that price, these sold for $3000 for a set. $150 is pretty generous i think.
They come with extra perches, and can be rebuilt near san diego at the Bilstein facility. No joke, this is the best suspension out there.
well, at the time I had Bilstein coilovers, I was just going to pair the hotchkis with the Bilstein and have then all revalved according to hotchkis specs.
1 - 20 of 20 Posts
