1 - 20 of 23 Posts
#1: oem main and trust bearing are good for hold 450-500whp??
#2:best turbo size for 91octane and 450-500whp?
tanks
yeah im in the same range.
to answer your question, yes i believe you will be fine with OEM main and thrust bearings. and using the MWR rod bearings
^^^ This.
Although if you're tearing the motor down anyways I would just go with the MWR bearings all around.
Discussion Starter · #10 ·
i think i stay with my first idea....pull my gt2876r at 17 psi(hope 350whp) and maybe more with 102oct...This morning I have to buy in mwr trd lsd for help my traction, with that i think im good for 11sec
Its a LONG way from 13s to 11s... Maybe on full slicks with a bunch of weight reduction, but mid 12s is a lot more likely.
i make 13.1 with stock engine at 11-12psi (269whp) no lsd with cheap street tire... with my new setup with slick you think im not good :(
Its certainly possible, but I don't think its guaranteed.
Discussion Starter · #15 ·
+450whp on 91oct? Not happening, bro...
wrong.
bt216 is around 440-450 on 91 pump gas. thats highest we have in CA at your everyday gas stations
yeah I currently have 446whp on 91 octane. I will have more soon because of boosted's manifold, ported head, and hopefully the higher psi wastegate springs will help too.
Discussion Starter · #20 ·
bt216 you make 446whp on 91 with gt30??
1 - 20 of 23 Posts
