Guys,
I could really use your help.
I am currently running the GT stage 1 kit @ 5-6 psi..
I want to install the crower FI cams and raise the boost to 8 psi...
What I was thinking is.. since the FI cams probably open the cams faster and further (and/or longer) more air will come in the cylinders offcourse, thus gaining power.
Will the FI cams generate more pressure on the pistons/rods than stock cams? More air + fuel = more powerfull explosion I assume..
I consider 8 psi still safe on the stock engine.. how about 8 psi + FI cams?
