1 - 17 of 17 Posts
well was my high school car...anyways any suggestions on what motor to swap in..and .currently running the original 20r but..dad wants to restore it completely..so if anyone has any input on where to start on the restoring process
Cartoon Porn Festival
I'm assuming that it is RWD so how about 3S-GTE (turbo motor) using the 93' MR-2 turbo tranny? It would be a great swap, although it is a heavy motor.
Or you could simply swap either a 3S-GE or a 5S-FE motor, again using a n/a MR-2 tranny.
Good luck with the project. Do you have any pics of it? I have a friend with a great condition 3rd gen Celica with the Kaminari kit, and its just beautiful.
how is a mr2 trans going to work?
as for your engine problem. please dont go outside of toyota for it.. do a 2jz or 1jz. hell try for the v8 a 3uz or whatever.
He could use the 3S-GTE motor for the MR-2 and its tranny. I am pretty sure his generation Celica is RWD.
Now along with this swap, you'd have to upgrade your brakes and most likely your axles.
Zettai Unmei Mokushiroku
The MR2 Turbo uses a FWD tranny...
Say what? :faint: Alright, thanks for the info BB.
Yup, the engine is in the rear, and the tranny is hooked up to it the same way any FWD car's is. No driveshaft, just axles straight from the tranny. He might be able to pick up an AllTrac's AWD tranny, though, and use that.
Even though thats still mounted FWD style.
Yup, but it's set up to be used as AWD, and you might be able to mod it to run as RWD only. I've heard of some WRXs doing that...
Huh...
I wonder how you would eliminate the front wheel drive
Discussion Starter · #11 ·
yup its rwd...the 3s is one of my choices..but anyone know anything about the 18rg ?...kinda wanna keep it as old school as possible...it would be sweet ...also anyone know how much it would cost approx to replace the whole interior..pretty sure the trunk has some rust damage...
ill take some pics this weekend...but its been sitting for a couple of years...but it worked fine when i parked it there
do a 22r.
Id say do a 22r and add a custom turbo. 22r's can be found for $500 from a yard and it should be really easy to get it set up. Existing tranny should bolt up too.
Discussion Starter · #16 ·
cool any advice on restoring the interior
the only thing I can say is search and search hard. that stuff is going to be 27 years old and almost impossible to find. Some places may still have a thing or two left in inventory.
If you are looking for a full restoration, use a 22R, if you are daring 22R-e (fuel injected). It would be more authentic.
1 - 17 of 17 Posts
