I went to AAMCO today to get my car diagnosed. I've been hearing clattering at certain points of the clutch especially in reverse and 1st gear. If I keep the clutch at a certain point it clatters. Their mechanic said it was most likely the damper springs on the clutch (ACT has four of those springs on the center of the friction plate) being worn. Does that make sense to you guys? Would it really clatter like that if those springs were worn? I'm not sure whether I should then really for another clutch change or not.
