The a/c compressor clutch is the part that needs to kick on. If it doesn't do anything or it cycles very frequently, it could be the pressure switch or low on freon.
check your ac condenser. maybe a rock chipped it and freon started leaking. or maybe an o ring started to leak. you can get it vacuumed, then fill with freon with leak detector and see where it is leaking.
