1 - 3 of 3 Posts
anybody know how to adjust the stock REAR cambers?...i installed a new suspension kit and was wondering how to adjust the rear cambers, because i heard the stock cambers go 2 inches both ways
This info would be helpful to me also.
camber, not cambers.
Anyhow, look underneath the car at the muffler (you shuold be lying on your back. On the back side of the muffler is a heat shield, just on the other side of that, in a very hard to reach location are the eccentric bolts for adjusting the camber.
step 1:
Loosen the set bolt.
step 2:
set the camber to the desired value
step 3:
tighten set bolt
step 4:
adjust the toe (same procedure as camber, but much easier to reach).
Edit:
Step 1: go to alignment shop and have them do it.
Scott
1 - 3 of 3 Posts
