You can use it to replace the stock o2 - it has 2 outputs - one is a zero to 5 volt and the other is a 0-1 volt that spoofs a factory sensor.Jesse IL said:Does it replace the front O2 sensor or do you need to weld a new bung on the pipe? I'm considering replacing my front o2 for maintenance, but I'd also like one of these. Wondering if I can kill two birds with one stone.
OK, now that I look into this thing, its looks like you only get the dual outputs when you purchase the separate controller. The gauge type controller only has the 0-5 output. With the Power FC, can you use the 0-5 output or do you still need the 0-1 output?Boosted2.0 said:You can use it to replace the stock o2 - it has 2 outputs - one is a zero to 5 volt and the other is a 0-1 volt that spoofs a factory sensor.
Hmm - thats odd - its supposed to be able to log any 0-5V signal via the additional inputs on the datalogit dongle box.Jesse IL said:Well this is interesting. I've been spending some time this evening reading the AEM forum and it looks like the AEM UEGO is a bad way to go when using a PFC and Datalogit. Apparently the Datalogit is unable to log the signal from the thing. I am gonna go register at the RX-7 board and see if I can find more of what these guys are talking about.
The thing has a "0-5V user programmable output". I looked at a wiring schmatic of the thing. There are four or five selectible modes for the output. The few RX-7 guys who were using the AEM UEGO with the Datalogit found that the signal was all over the place, even after spending lots of time chasing power and ground ideas. One guy said he found the same problem when using a Techedge wideband. I have two concerns. One, using the AEM EUGO, will the PFC even be seeing a clean signal? Also, what voltage input is the thing looking for? It would kind of suck to get a nice 0-5V wideband sensor and then have to use the lower resolution 0-1V output.Boosted2.0 said:Hmm - thats odd - its supposed to be able to log any 0-5V signal via the additional inputs on the datalogit dongle box.
and like Tomcat says the gauge type should have both outputs.
BTW don't ask me how to interpret that info, it was someone who had a question on hooking one up to his SR20DETsteve
you do not need to connect the 0V connection on the datalogit. But instead, i would recommend connecting 0V from the techedge to AN2 of the FC-Box, then selecting "Delta AN1-AN2" on the Setup->Auxilary window. This will help eliminate any "ground loop" errors.
I would also check what raw AN1 voltage you are logging. 14ish AFR should be around 2.5V whereas 9.08AFR you are seeing sounds like ~0V.
Steve
They are probably using the sensor ground on the ECU - I have noticed that widebands are very noisy when you use that ground. I now use the body ground from the factory O2 sensor for both of the wideband ground circuits on all the widebands I wire up, and it works like a charm.Jesse IL said:The thing has a "0-5V user programmable output". I looked at a wiring schmatic of the thing. There are four or five selectible modes for the output. The few RX-7 guys who were using the AEM UEGO with the Datalogit found that the signal was all over the place, even after spending lots of time chasing power and ground ideas. One guy said he found the same problem when using a Techedge wideband. I have two concerns. One, using the AEM EUGO, will the PFC even be seeing a clean signal? Also, what voltage input is the thing looking for? It would kind of suck to get a nice 0-5V wideband sensor and then have to use the lower resolution 0-1V output.
Unfortunately, these guys had gone as far as wiring the thing directly to the battery, so I don't think that is the case.Boosted2.0 said:They are probably using the sensor ground on the ECU - I have noticed that widebands are very noisy when you use that ground. I now use the body ground from the factory O2 sensor for both of the wideband ground circuits on all the widebands I wire up, and it works like a charm.
