Blue Bomber said::moved:
Depends on what you like better: handling or acceleration/sound.
FoolioABC said:Unless you know what you're doing, installing springs in the rear may be pretty difficult as well, and you may have to pay like 300 dollars to get the springs to installed. Just a heads up, I think installation and cost should factor into your decision.
So are you in Garden Grove (not ment to be an insult)?Originally posted by jl2fast4u
asian ricer neighbors next door (not meant to be an insult).![]()
SatansLilCelica said:So are you in Garden Grove (not ment to be an insult)?
True, but I have a different plan. I'd like to pull the struts off myself and then run to one of the local shops to have them compress and change the springs for me on the strut, then I'll reinstall then myself. Saves money and doing the easy part myself. Good plan?FoolioABC said:Unless you know what you're doing, installing springs in the rear may be pretty difficult as well, and you may have to pay like 300 dollars to get the springs to installed. Just a heads up, I think installation and cost should factor into your decision.
KNanthrup said:True, but I have a different plan. I'd like to pull the struts off myself and then run to one of the local shops to have them compress and change the springs for me on the strut, then I'll reinstall then myself. Saves money and doing the easy part myself. Good plan?
