1 - 3 of 3 Posts
The A/C in my car is cold however when I have my A/C on the A/C light flashes and then it stops blowing cold. Is my A/C compressor acting up due to the A/C light flashing? Or is it something else all input is appreciated.
not sure what ur problem is, but i would get it checked out. Last time i saw an ac light blinking on and off and stop working was on my camry. the ac died and ended smoking as i drove. seems like the bearings broke and the compressor was grinding metal.
my a/c light was blinking a long time ago. it ended up being the magnetic clutch relay. go under the hood and switch the the magnetic clutch relay with the horn relay and see if that helps.
1 - 3 of 3 Posts
