RichGT said:
You dont need them. The machine that gives you the alignment give you all the specs you need.
And that my friend is why you car does not handle well.
One can get more "improvement" out a good aligment that many suspemsion modifications.
guyver858: You settings depend a lot on what you plan to do with the car.
For normal "spirted" street driving I'd go with
Front Camber: -1.5 degrees
Front Toe: 0
Rear Camber: -1.3
Rear Toe: 0.1 degrees in
For Autocross like handling try
Front Camber: -2.0 degrees
Front Toe: Just a little toe out, maybe 0 to .05 OUT
Rear Camber: -1.3
Rear Toe: 0.06 to .04 degrees in
note: The autocross setting car make the car a little "twitchy" on the street, just pay attention when driving.
