I just did my own alignment, but I got into an arguement with my co-workers and I didn't get to finish.
But I'm still not sure either.
For a GT with 16s. Lowered with H&R springs. 1.3 inches. front to rear.
Front left -0.46 degrees camber and front right -1.02 degrees camber. cross camber 0.56 degrees.
Front left .04 degrees toe and front right .01 degrees toe. total toe .05 degrees.
Rear left -1.38 degrees camber and rear right -1.13 degrees camber. cross camber -0.25 degrees.
Rear left 0.12 degrees toe and rear right 0.08 degrees toe. Total toe 0.20 degrees.
Thrust angle 0.02 degrees.
I used factory specs, but my co-workers say my adjustments are within tolerance. I'm not happy with front right camber. But not sure if I should redo the whole thing and get the adjustments closer to factory specs.
thanks.
thanks.
