1 - 8 of 8 Posts
I own a 2000 Celica GT-S and i was having trouble finding a wiring harness that plugs into the existing stereo harness and that could take use of the existing amp that is in the car itself.... i have looked and there is a solution besides the schose, and other knockoffs.... Metra makes a 20 pin with rca adapters that plugs into factory harness and eliminates any alternator whine that may exist..... you can order them from your local car audio shop i think the number is 70-813 but im not completely sure :thumbup:
and it still requires modding... been covered...
no need to make 2 threads of the same thing... :wtf:
and i already gave you the answer to search for in your other thread...
Search, my friend. People have had the same problems w/the Metra as the Scosche.
there are two metra's one is plugged into the amp and that is the one that is considered the one with outside noise or as far as i have looked into
i dont think you get it, raging and 2way have already said it, its been covered and the metra still needs modding. How do i know? cause i was the one that tested the metra harness, and its the 70-8113 model. Im still getting alternator buzz with my harness and i have been too lazy to add resistors to my harness.
^that is exactly correct...both harnesses (metra/scosche) will fit your stock plug; however, you will need to additional resistors to avoid static noise cause by alternator and other source...
1 - 8 of 8 Posts
