1 - 4 of 4 Posts
I'm new here, so excuse my ignorance.
I'm going to install 2 amps to power aftermarket speakers and need to wire them directly to the battery. Where's the best place to get through the firewall?
GTS Turbo
above gas pedal there is the main harness use that grommet.
This, but depending on how thick the wire is, You might consider drilling a larger hole an inch up and to the left of this groment. You can purchase a seperate rubber groment at your local auto parts store to preent the wire from rubbing on the metal.
Or you can relocate your battery to the trunk like I did and your wiring issues are solved.
1 - 4 of 4 Posts
