1 - 4 of 4 Posts
I have a 00 GT-S
When I rev my car up to about 6,000rpm a squealing noise starts. Its a high pitch annoying noise and it will continue until my car physically comes to a stop. There is no noise until it gets reved up a little. After the noise is apparent, I threw it into neutral to see if the noise would stop when the car was still moving and the noise continues. Its not until I come to a complete stop that the noise stops, and there is no squealing when the car is just idoling. There is no difference when the car has the A/C on, and I had the brakes are good.
I took it to toyota and they don't know what it is.
If you have any ideas on what it could be please tell me, thanks.
Bring on the 12's...
Sounds like the drive belt. I have had that problem for months!!! lol, i cant find the correct sized belt. I think the stock size needed is 6pk1940 for a stock set up.
check your shims on the edge of your brake pads, thehy could be rubbing against the rotors, i saw someone with this problem before, and he let it go on for so long that the shims actually seperated the hub from the rotor == brakes not workign because rotor spins independently
Belt tensioner. If your hearing a sqeaking pull on ur serp belt the one that goes on ur alternator if its lose then theres your problem.
1 - 4 of 4 Posts
