Hi all! I'm new here and I'm "rebuilding" a 2zz which will be installed in my mr2 spyder.
Thing is, my 130.000km engine has a wiped intake cam, which i'm replacing with a new oem cam and rockers i bought from Partsouq. Since i pulled the head to replace the valve steam seals which were leaking and im trying to do everything as right as possible, i wanna try to fix this issue for good. The car will see daily and track use, i also bought a brand new oem oil pump and a seriously lotus baffled sump. Here's the info i've gathered as to why the intake cam may have wiped:
-I measured the valve lash with the new cam (the proper way, installing only 1 shim per rocker, measuring between cam lobe and roller, pulling the cam again, removing those shims and installing the other ones, install cam, measuring again...). Long story short, the loosest clearance was 0.09mm and the tightest 0.06mm. I already ordered 8 shims from toyota to set all intake valves to a 0.20mm lash (0.02mm looser than the max tolerance the manual allows). As usual, the exhaust cam shows no wear and the lash was 0.25mm on all 8 valves, so i'm not worrying about that one and let it be.
-The rest of the engine is pretty good looking aside from a bit of sludge, the rod bearings and cylinder liners look mint so i dont think it used bad engine oil on its previous life.
The question is, what more can i do to prevent the cam from wiping again? I've read a lot and couldnt come to a conclusion. On the first 100 miles of engine testing, im thinking of running some cheap 5w40 oil (total classic) and a xenum flush to clean a bit of sludge. I've read that some people strongly advice to break in new cams, specially in engines with flat tappets (which is the case for 2zz lift lobe), but i dont know how to bed that, i dont think it would be healty to drive the car for a few minutes at a constant +6000rpm, since it would be useless trying to bed the lift lobe with the tappet without lift being engaged, dunno if im making sense?
Thanks a lot in advance, regards, Ivan.
Btw, here are some pics of my wiped cam, it wasnt terrible, but... i think it only was a matter of time.
