1 - 3 of 3 Posts
Shop i last took my car to seems to have taken out the plastic pipe above the throttle body. It goes into the ECU. What exactly is this for and what if any danger does it hold for not being there? Will it hurt performace any? Also where the whole used to be they seemed to have blocked it off with a piece of plastic. Anyone with any ideas?
That is used to cool the ECU, why did they take it out? Did you have a CAI installed? I'd go back and tell them you want it back then put it back in. You wouldn't want the ECU to overheat and malfunction. It may cause some problems down the road.
1 - 3 of 3 Posts
