1 - 7 of 7 Posts
Mine seems to be making a whirring noise, kinda like a supercharger whine. I'm not sure if it just started doing it or if they all do that.
Mei's alt just went out a couple of weeks ago, replaced under warranty. 59k miles '00 GTS.
Zettai Unmei Mokushiroku
Are you sure that it's the alternator? I know the water pump is supposed to make noise when its bearing starts to go, and it's located directly behind the alt. Take off the belt and see if the water pump is hard to rotate.
i had my alternator go out at 38k and it wasn't replaced under warranty, :( i was pissed, i called toyota corp and asked why did it go out so soon, blah blah. The answer I got was, things just happen and you're pass the 36k bumper to bumper nonesense. I had to folk out 600 bucks for a new one, (parts and labor). Oh well. I'm not sure it went completely out or not but my battery light came up and I took it to the dealership and thats what they told me. Good luck.
Discussion Starter #5
It could be either, but I traced the noise to that location.
She has the Platinum 100k warranty so they replaced that and we also made them replace the sunroof :chuckles:
Why don't you just test the charging system?
with the car off, the battery should read ~12v.
With the car on, the battery should read 13-14v, I believe.
1 - 7 of 7 Posts
