1 - 9 of 9 Posts
Hey guys, about a month ago, i swapped my fuel injectors from a 2003 Celica GTS (yellow injectors with 4 holes) to my 2001 Celica GTS. it had these green fuel injectors in them with 10 holes) I can't seem to find anything about these green injectors, so can someone give me some more info in them?
found the part number 23250 0h030
Weird. These are from a Scion TC? huh. I got the car with these in them.
From what I can tell, those greenies are for the 2AZ-FE 2.4L engine.
2AZ-FE 2.4L = 2362 cc
Flow rate appears to be 332cc/min.
There is a set of greens for the Celica.... I think the p/n is 23250-0D040
greens are for the 1ZZ, for a 2zz you want brown or yellow, I believe there is a gray or blue set that is also usable. Google the part number and you should be able to see what kind of flow numbers are out there
Discussion Starter #7
I got part number 23250 0h030, I'm just gonna run with these green ones, CC seems to be higher, and a better spray pattern, so the ECU Should be able to compensate.
The Green injectors can either be stock 1ZZ injectors or the 440s from the Lotus Elise/Exige S - either way if you have a standalone get ID1050X
1 - 9 of 9 Posts
