Lol right, im fairly confident its the brown wire which i believe is pin 5.Like beetelguese you gotta say it 3 times…
But be careful what you ask for.
Yeah i meant maf plug i just wired in a map sensor before i wrote that. I plan to use the temp wire an the ground for a IAT sensor i added.Celica doesn't have a MAP, it has a MAF. Look at the Engine Control schematics in the Electrical stickies for the MAF wiring.
Piggybacks just remap the readings.
Sorry for delay. Been traveling a lot.
And yes, BRown is the gnd. It is NOT switched.
Hows that work tho, if the PCM has it defined as X volts = Y airflow so you get a box that takes MAP, TPS, and IAT and calculates an airflow which it puts out as a voltage to the ECM it would still referenced X=Y? I clearly have a lot of learning to do, I need to know the how of things work not just that they work.Piggybacks just remap the readings..
The piggyback will bypass the ecu for anything in regards to the running of the engine. Its hard to explain without showing the harness adapter.Hows that work tho, if the PCM has it defined as X volts = Y airflow so you get a box that takes MAP, TPS, and IAT and calculates an airflow which it puts out as a voltage to the ECM it would still referenced X=Y? I clearly have a lot of learning to do, I need to know the how of things work not just that they work.
Hey @2way is one of these other wires a 5v supply??? I need a 5v supply so i can add a fuel pressure sensor so i dont have to use up an extra pin on my piggy back. Tryin to maximize switch ports an im runnin out of room.Celica doesn't have a MAP, it has a MAF. Look at the Engine Control schematics in the Electrical stickies for the MAF wiring.
I meant like the actual piggybacks in days of yore lol, but you're running a standalone with parallel wiring which is likely where I'll end up since I want VVT control. I get how that works, but like the old Greddy E-manage systems and the like. It's ok, those dinosaurs are long dead. Idle curiosity.The piggyback will bypass the ecu for anything in regards to the running of the engine. Its hard to explain without showing the harness adapter.
So the main engine running wires do not even end up making it to the ecu as you can see above
2000 GTS Turbo
