1 - 19 of 19 Posts
hey guys/gals i have a question well first off i have a 2000 6speed gts, now for those of you who have one the first to second gear shift is damn hard to land in lift, i was wondering if a short shifter could help with this? if so which one would be good to go with? i was thinking the twm or the trd? well thanks for the input.
p.s i would of did a search but i just wanted to make sure my questioned was aswnered.
id suggest goin with a trd .. its crisp ..and smooth ..and it would somewhat help .. but u do need to shift a lill quicker it sounds like
Do a >search< on landing in lift on 1-2. Search "shift lift" or some other combination. FYI the Celica was not meant to stay in lift on 1-2.
why is it not meant to stay in lift btw?
North East OG member
the celi is not supposed to stay in lift when shifting. I'm not too sure how to explain it but it has to do w/ the gear ratios. the gear ratios make is fall to about 5700rpms when shifting 1-2. that's why most people slip the clutch a bit when shifting at high rpms to stay in lift
good point:) if it was meant to stay in lift..then it would easily be done jus by revving to redline and calmly shiftin;)
I got the TWM, landing 1-2 is no problem.
At first I was a little upset because I wasnt landing above 6k but it just took some gettin used to with the twm. At first its a little hard to shift, its really stiff, but it loosens up after a few weeks. I love the it.
Its ALL about the driver...
I don't own a GTS, but the first time i ever drove one, it was the drag stip, and landing the infamous 1-2 shift was done w/ no problem (no SS was involved).
Sure, its a tricky move, but its def. possible. Work on becoming a better driver.
how are you becoming a better driver by shifting incorrectly to stay in the powerband. You are almost powershifting in order to stay in the power band.
yea its hard to land in lift in a 02, but i can do it now most of the time, check my mods, i hated my twm at first, it was so stiff, i had the hardest time with my 1-2, with bills motor mount, and redline tranny fluid, its smooth as butter now
I ve read that people with the fidanza (that is lighter than TRD) can still land in lift on 1-2 shift.
is this true?
1 - 19 of 19 Posts
