41 - 60 of 241 Posts
Turbo 2zz
I talked with MWR today via email. Basically they discouraged the whole idea and said just to swap in a full 3s-gte swap. Which is IMHO fucking stupid. Their e153 kit should mostly work, ie the passenger axle wont work but could be modified. They also talked about the steering rack being in the way but I kinda figured it would be anyway.
to solve the steering rack issue you can machine rod stock into a spacer and put it between the k member and the frame. you would of course need a longer bolt but it would give you the space you need
Discussion Starter #43
With the reading I have been doing I don't think that steering is going to be a problem. The candida uses a very similar chassis. I'm pretty sure this is going to be plug and play
Sent from my XT907 using Tapatalk
Turbo 2zz
okay i see now you are going to use a completely new k member. very nice. looking forward to updates. I have plans for a 2zz rwd celica and if the caldina front k member has enough room to clear then that will work great for me as well
Discussion Starter #45
No the stock one. My current plan is MWR e153 kit, e154f transmission, and a Caldina rear clip. The only thing that needs to be fabbed as of now us a exhaust.
I know the Caldina K-frame is a little bit deeper than the Celica K-frame, allowing more space for the driveshaft and exhaust.
Sure looks tight with Celica frame.
Discussion Starter #47
Not worried about the front, I'm really just concerned with the rear. If I can get all that to bolt up, I'll start buying parts
Discussion Starter #53
That looks like a factory gas tank
IM thinking it might be easier to just get a whole Caldina imported
Discussion Starter #58
I took a look, nice pictures, they used the rear end out of a AWD Corrolla, which i have never heard of and made some custom brackets that were welded in and what not. Im really searching for something more bolt in.
Discussion Starter #59
I found a couple of awd matrix and vibe rear clips and rear sub assemblies. Going to call Monday and see what they come with and cost to ship. Get this project going
Discussion Starter #60
I found the key components not far from me. Hopefully have them by January. Sad part is I wont be able to install them till March.
