1 - 2 of 2 Posts
Hi all im new here,
ive set about installing a bee r rev limiter (launch control, flame thrower) what ever you want to call it,
I drag race my 2000 celica vvit 140 bhp 1zzfe every summer at the local strip when its open,
the instructions that came with this thing are wrong!!!
I need to know what wires that go into the ecu, I need to know the ignition signal wire and the rpm signal wire (crank shaft sensor)
basically all this thing does is make the rpm bounce at what ever revs you set it to with 3 settings, rev 1 (handbreak on) rev 2 handbreak off and the pitch of the ignition cut (fast or slow bounce)
2zz swapped 03 celica gt.
Have you installed it I’m doing the same thing but I can’t seem to find the ignition wire to tap into.
1 - 2 of 2 Posts
