1 - 2 of 2 Posts
Cross posted from spyderchat....
I have a 2002 MR2 2ZZ swapped. There is an oil leak going on and I'm pretty sure its the head gasket.
I know I should check to see if its warped then....
1. Can anyone post youtube videos or links on how to change the head gasket?
2. What should I upgrade while I have the head off for reliability?
3. Any other tips would be greatly appreciated!!!!!!!!!
This is my first time taking the head off the car. wish me luck!
Why you so sure that its the head gasket? What i know is when you have a blew gasket you will have a mix between the coolant and the oil and when that happens if you don't stop and fix the problem you will kill your rod bearing
1 - 2 of 2 Posts
