1 - 7 of 7 Posts
ok..i've had this problem for quite awhile now..on my front bumper (bomex) the left tab is broken..how do i fix this?? i've used Ultimate Bondo but it still won't hold the hole i made for the screw to go into that attach to the fender..
wat other option do i have?? or wat can i do to make it better?? fiberglass resin?? don't even know how that work..
thanks
if its a fiberglass bumper use fiberglass...if its urethane thats y bondo wont work...........wat about relocating the tab a little bit away from the broken area
d*mn it..no wonder bondo won't work..it said it'll work for fiberglass too..that's y i bought it..i want to use the stock hole so i don't have to drill a different hole on the fender..
wat do u recommend?? something cheap please..i don't want to buy a big a** can for a small repair..
1 - 7 of 7 Posts
