Anybody know where i can get a lesson in doin brake pads. I wanna change them out today! But i never did it before so i wanna know exactly what has to be done.
Find someone that has done it before that will help you and teach you the first time. Don't do it by yourself, there is too much that can go wrong if you don't do it properly.
Ok, so im in the process. I have the new pads in but i dont know how to retract the caliper pistons to fit the new thicker pads. Anybody know? TRD StreetRacing I assume you had to do this somehow! hehe howd ya do it?
You need a big C clamp to push the piston back in.
- Uncap the brake resevoir under the hood.
- take an old brake pad and place it over the piston to give u a flat service over the piston, and tighten the c clamp till it's pushed back in.
don't forget to use brake cleaner on the shims and put a good amount of brake grease in between the shims after.
Ok, thanks guys, i guess i just have to squeeze harder. Seemed pretty damn tite! TRD StreetRacing- Im doin the fronts now, but I have to do the back as well.
haha new problem. I have the whole brake situation figured out, but now i cant get my other rim off. I cant believe this, all the lugs are off and the rim is stuck there. I pulled hard enough to slide the car and nothing. WTF??? Arghhhhhhhh
it's pretty hard to push back in if you don't have a clamp
EDIT: PM me if you want. sometimes the rim gets stuck onto the hub. just kick the bottom of the rim/tire once and the top part of the rim will tilt forward. that what i had to do to mine
hehe thats exactly what i did. I just started kicking it and it came off. Anyway, all done, just went out and there working nicely. I'll have to do the rears sunday. It's amazing, that right pad took me like hours, and after i knew the routine i did the left one in about 10 minutes. The worst part is my car is too low for the jack so i had to go through a whole routine to get the car raised. That brought back my headache for sure!
