1 - 4 of 4 Posts
Hi Guys,
I started to concern about my brake making so bad noise when I am backing out of house every morning. Is this normal? The noise is very bad, it only does it when you are in reverse not drive. The brake pads look ok. Any suggestions are appreciated. Thanks.
clunking noise? are your sure its the brakes?
anything loose on the brakes themselves pads or any clips holding the pad?
Not a clunking noise, more like grinding noise metal to metal, only does it when I am backing it "reverse".
1 - 4 of 4 Posts
