Hey tried to pull lift bolts the first one closest to the front of car was broke at the bottom above tapered piece. So I tried to a couple of the extraction methods and they were unsuccessful. In fact I stripped the threads off the hole! So now I put it back together with no bolt in the hole because I didn't want it flopping out and rolling around loose in there.
So I was thinking the if I drill out the remaining piece and run a little wider bolt in there would this fix the problem? If the bolt is the same length as the stock one? Can I run new threads in that hole and if so would the stock bolt fit?
Any suggestions?
PS The car seems to rum fine I'm not sure how long it was broke I have 115,000 miles on it.
Late
Any suggestions?
Late
