1 - 4 of 4 Posts
hey guys went to replace my lift bolts this weekend and one of them is broken how do i get the bolt out please help
Has your rocker arm rotated at all? If it hasn't you can use a bit extracter to get it out. It takes time but it works. If it has rotated you're sorta screwed.
you are not screwed, you just have to do more work to get it out. you have to pull the cams, remove the lift actuator system on the right of the head, and tap out the rocker shaft. remove the broken piece and put all back together...its not too hard, i can do it in about 4 hours. and i dont even have to pull the motor he he he
lol Yeah I have the guide on how to do it that way, I'm just sorta scared to, and I'm guessing he is too.
1 - 4 of 4 Posts
