1 - 2 of 2 Posts
any experts on buffers that can offer some tips?
is it bad to always use a buffer to wax the car?
thanks,
vinnie
It is not bad to always use them (if you are using them correctly with the correct products) but it not necessary IMO. For compounding/polishing out surface imperfections they are terrific. For waxing and wiping clean there is no need IMO. It takes longer for me to use a machine to do a simple wax job than it takes by hand.
Let's not confuse terms. What machine are you using? What application pads/bonnets are you using? What products are you applying? What are you using to remove them from the paint?
Run a search in W&W for the term "buffer" and you should come up with several threads.
1 - 2 of 2 Posts
