Well yesterday I took off my valve cover to check the cam timing that I suspected to be off. Sure enough it looks like it was. Here are the pics:
By chain marks:
By setting the crank to TDC:
^^ these marks should be offset. The exhaust cam mark should be up a notch. I think the dealer set it in a straight line b/c thats the way it looks in the service manual, its confusing.
If you look at the chain marks it looks advanced by 2 notches, but when you look at the TDC marks, it looks off by 1 notch since the marks are even.
I'm not going to attempt to fix this myself, but was wondering if anyone has any insight why this is.
.. this is a 2003 GTS btw.
By chain marks:
